what is the best way to remove dried blood from cotton?
I have a hand-made, cotton quilt, with small splatters, over a large area. There are top colors scattered over a country white background & backing to add to the challenge. Thank you!
canucksgirl says: Jul 30, 2012. 1:41 PM
Tide To Go Instant Stain Remover pen. I bought one a while ago, and they work GREAT on pretty much everything including blood. It doesn't bleach, so its safe on colors, but it gets rid of stains.
dragonfly55 (author) in reply to canucksgirlAug 22, 2012. 9:01 PM
does it hurt fabric--this would be my only concern as tide is normally hard on more delicate materials. my quilt has some material piecing that has some life to it--saved from special pieces of clothing--from the past.
canucksgirl in reply to dragonfly55Aug 31, 2012. 12:18 PM
I've used it on many fabrics and my mom has used it on one of her heirloom quilts without problems, so I would say yes, it is perfectly safe to use. It's not a 'pre-treater' so you can just use it to remove the stain and let it dry and that's it. I keep one in my purse for those dreaded coffee drips. It's very handy to have. (Even though I don't use Tide detergent for washing). :-)
dragonfly55 (author) says: Aug 22, 2012. 9:05 PM
thank you everyone! i am still working on the quilt piece by piece -- your help is much appreciated!!
mpilchfamily says: Jul 30, 2012. 11:00 AM
Hydrogen peroxide. Dab it into the cloth and let it sit for a minute. Then dab it with a dry cloth and repeat. It will take some time but eventually the peroxide will eat through all the blood.
dragonfly55 (author) in reply to mpilchfamilyAug 22, 2012. 9:03 PM
thank you
CatTrampoline says: Jul 30, 2012. 11:50 AM
The first step would be to soak in COLD water first, to remove as much blood as possible. Then treat with an enzymatic stain remover such as Shout. Let the stain remover sit on the blood spots for about 15 minutes, then wash according to label directions.
Before drying, check the spots. If some of the blood is still there, re-treat and allow the enzymes to work their magic for several hours before washing again. If the stains are set by the dryer they will be even harder to remove.
I realize this is a DIY site, but sometimes a commercial product is the best choice. Hydrogen peroxide is great at eating blood but it will also make "bleach" marks on dark colored fabric.
dragonfly55 (author) in reply to CatTrampolineAug 22, 2012. 9:02 PM
thank you
Vyger says: Jul 30, 2012. 11:10 AM
Your not supposed to wrap bodies in things you want to keep.
dragonfly55 (author) in reply to VygerAug 22, 2012. 8:47 PM
i know but some things can't be helped
bwrussell in reply to VygerJul 30, 2012. 1:48 PM
Or at least wait until everything is coagulated.
I've always heard cold water but typically that works best on a fresh stain. How long ago was the body dumped?
dragonfly55 (author) in reply to bwrussellAug 22, 2012. 8:49 PM
to long to get the stains out easily
steveastrouk in reply to VygerJul 30, 2012. 1:25 PM
Best answer.
lizzyastro says: Aug 6, 2012. 6:12 AM
The advice I have heard on this from quilters is that the provider of the blood should spit on it! Apparently the enzymes in the saliva work on the proteins in the blood. If you cannot get the bleeder to do this then a long soak in Biz is recommended followed by laundering as usual.
iceng in reply to lizzyastroAug 6, 2012. 12:37 PM
This is an amazing concept !!
lizzyastro in reply to icengAug 7, 2012. 2:33 AM
I don't know how effective it really is or if it is just a myth - as I machine quilt I don't usually prick my fingers sufficiently to bleed on my creations and have had no need to try it out :-)
Lizzy
iceng in reply to lizzyastroAug 7, 2012. 10:26 AM
Next time I measure my blood sugar I will add blood to four cloth patches
to test after an hour and after 2 days by me and my wife.   Let you know.
A
steveastrouk in reply to icengAug 7, 2012. 1:13 PM
The true spirit of scientific experimentation is alive and kicking in Nevada.
iceng in reply to steveastroukAug 17, 2012. 3:17 PM
So I have put blood drop stains on six white fabric squares.
The first two were salivated upon by my wife and I after 2 hours and
rubbed fard and rinsed with little remaining red but no difference between
the saliva.
Three days later two other squares were salivated upon and rubber hard
followed by a water rinse.
More blood remained and no appreciable difference between my wife and I.
The conclusion is it did not appear to make a difference whose saliva enzymes
were used on my stain...
A
iceng in reply to steveastroukAug 7, 2012. 1:19 PM
mole1 says: Jul 31, 2012. 4:56 PM
Before doing anything else (like washing/drying it) soak it ammonia and cold water overnight. This works best when the bloodstain is recent. For something as big as a quilt, I would probably put six inches of water in the bathtub, open the window, add maybe a pint of ammonia, and then add the quilt. In the morning, pull the plug, and turn on a cold shower. When the ammonia was pretty much gone, I would put plastic bags on my stocking feet and carefully walk on the quilt to squeeze out most of the water. If you do this by hand, wear glove to squeeze (do not wring) the water out.
iceng says: Jul 30, 2012. 10:12 PM
H2O2 Peroxide..
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
