what wattage of laser necessary to kill mosquitoes (immediately)?
To craft a gadget that shoots mosquitoes with laser, there is the need to know the enemy's vulnerability. The most needed is the mosquito vulnerability to laser shooting. What wattage of laser is sufficient?
The configuration I think is, attracting mosquitoes with some infrared light (or, multivibrator), then shooting with laser. I might shoot with a continuous laser (after infrared path is broken, surely), but zip-zip-zip sort of (threshold activated shooting) is sensible, too.
I stated this previously @ yahoo answers, but no (serious) answer wa there.
See the question there, http://answers.yahoo.com/question/index?qid=20090505022002AAnd31e
For a full, energy-harvesting mosquito-shooting gadget, a previous question might be related, too. That next question is about the malaria map (for energy harvesting, where necessary). http://answers.yahoo.com/question/index?qid=20090405004614AAsBwtL
Oct 29, 2012. 9:03 AMjames34602 says:
I thing you should measure the distance of the mosquito and your laser emitter
100w can kill mosquito immediately in >20m
But you may get burn
200mW in 10cm was painful enough
Jul 16, 2010. 8:56 PMKalrag says:
I would say a good 1500W laser should stop them in their tracks or flight.
Jan 26, 2012. 6:17 PMdontkillpenguins says:
that is military grade and can burn meatal
Jan 8, 2011. 10:53 PMTheIronHobo says:
Mosquitos font eat blOod the females use it to propagate find a mosquito food put it in a box with one open end then find a 5 mw line laser pointing on several photocells which let electricity pass with direct light to the same switch that will trigger with no electricity like the opposite of agreed relay then directly and immediately further down the box would be a 3 watt line laser which is a laser with its beam narrowed into a line that will be attached to the deadmans electricity switch. So when the mosquito blocked the wimpy 5 mw line it would be blasted with 3 watts of simulated radiation. this all depends on the sensitivity of the photocells. You would have to put a Capacitor on the burning laser so the beam would remain on for about 5 seconds. Just pulled this outta my hat let me know what you think or how'd you make a computer program that can gun down Mosquitos .mine would work better with flies.
Jul 28, 2010. 1:55 PMemihackr97 says:
i will sugest 2000 milliwatts (2watt) that actually is really powerful. normal laser pointers are between 1 end 5 milliwatt and can still get you blind!
Apr 19, 2010. 4:27 PMmyc1034 says:
remember that females are larger than males and they beat their wings faster (different frequency) than the males as well. i you can figure out the frequency of females(less females=less eggs=less mosquitoes) and use that as the basis of the targeting system.tho that will not solve the problem of civilian casualties if they land on people(which is the basis of this project). as for killing the mosquitoes you only need to vaporize their fragile wings which will take away their primary mod of transportation and make them more susceptible to predators.
Apr 3, 2010. 8:45 PMCheathum14 says:
Funniest question ive seen all day :)
About a thousand watts should vaporize them for sure. Just make sure you dont point it at a mosquito thats on you cuz it might sting more than the mosquito itself.
Jul 6, 2009. 12:11 AMDr.Bill says:
Naaa. Just use a 500w C02 laser just to be sure hook it up to a computer pointing device with sonar sensing.
Sep 2, 2009. 4:29 PMmatt ledding says:
Wow. Practical ideas really do trickle down from military technology... ; ) Velcro, Duct tape and the backyard Star Wars Missile/bug Defence System.
May 22, 2009. 8:52 AMAndyGadget says:
One of THESE ought to do it.
Sep 18, 2009. 7:00 PMDr.Bill says:
NOW YOUR TALKING ! I GOTTA GET ME ONE !
Sep 18, 2009. 7:02 PMDr.Bill says:
NO. NO. 2. I gotta get me 2 .
May 22, 2009. 5:55 AMelectrosam says:
The basic to kill mosquito by Laser is the heat generated by laser radiation. I guess a laser of about 2W would be enough. But remember this could be harmful to us.
Sep 18, 2009. 6:59 PMDr.Bill says:
naaa. Got to make the laser powerful enough to not be dissipated by the atmosphere. 500 watts with a sonar pointing device attached
May 22, 2009. 5:28 AMBigev says:
How would you aim it at their tiny bug bodies?
Sep 18, 2009. 6:56 PMDr.Bill says:
The same way a bat aims itself at bugs.
May 22, 2009. 2:42 AMrickharris says:
too high to be safe hence the commercial high voltage bug zapper type of approach.
Jan 5, 2013. 12:09 AMDr.Bill says:
The transformer off the bug zappers makes a good burglar deterrent
May 24, 2009. 8:51 AMrickharris says:
Correct - bits of fly everywhere They are not thinking when they put them in food shops!
Jul 1, 2009. 10:37 AMmatchett808 says:
hm...I dunno but i would say that you should probably build a machine to catch them then kill them as slow as possible say....by pulling the legs then wings off?? *{instert favourate makebeleive charecter here}* - I hate bugs
May 24, 2009. 10:57 AMmman1506 says:
any thing that would start to be hot on your finger so im thinking about 5w what about a torch that goes off when tripped because i found mosquito's dye with very little heat
May 28, 2009. 2:18 PMmman1506 says:
ive found that most bugs die with very little heat hence an torch but to really work quick you probably need a laser that can instantly light a match. why i suggested it was once a flie went over a candle (not in) and immidentally died .you dont need to vapourize an mosquito to kill it
May 23, 2009. 12:56 PMReCreate says:
1.6 Gigawatts,It will Require a flux Cap :P Any Laser That Would Burn your finger immediately:),Say 1 Watt?,Tops? Maybe a DVD Burner or Blu ray Burner might work.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
