loading
whats a good design for a mini balsa wood bridge? it has to hold 100 pounds!?
must have:
mass- 45.0 grams or less
length- must be longer than 38.0 centimeters (2.0 cm by 2.0 cm square rod must be able to pass through full length of roadway surface)
height & depth- can't extend more than 12.0 cm above test support surface and 10.0 cm below it.
roadway- will support 100lbs load, cannot be more than 2.0 cm above test support surface
BRIDGES CAN'T BE WEDGED INTO SUPPORTS)
someone please help, i'm stuck!
lemonie6 years ago
Homework question yes?
Listen: this is a classic school project, millions of kids have done it / similar. Go looking for the same.
http://images.google.co.uk/images?hl=en&source=hp&biw=1408&bih=883&q=balsa+wood+bridge&gbv=2&aq=6&aqi=g10&aql=&oq=balsa
L
+1.
frollard6 years ago
triangles.
Tetrahedrons - there's no requirement in the spec for traffic to be able to actually cross the bridge.
no, just the hollow passage - no 'deck' required per se. tetrahedrons for the win.
