whats better for electrolysis, 12vdc or 24-70vac?
right now, i am clueless as to what is better, a 12v dc @500ma battery charger , to electrolys salt, or, a christmas lights power supply station wich gives out 24-70 volts ac, at something around 1-3 amps. though some research i have not been able to determine wether ac is better and safer than dc or vice versa, when making chlorates in electrolysis. i have heard that ac apparently is better because it generates heat which allows for a faster reaction than dc, but also ive heard ac power at those voltages may just jump from one electrode to another through the air, and not do any electrolysis at all. whereas dc is just weak.
someone pleas ehlp me out!
7
answers
Answer it!
strange, because i remember in science class that , in abook explaining electrolysis, it said an "ac current is used", not dc.
also, you say that its the wattage that is what does electrolysis, not the actual voltage, in relation to the current. aka 12v @ 100ma wont do more than 6v @ 10A.
because i do have access to a charger that gives out 9v @ 2A
lastly, is it safe to put dc power outputs (battery chargers) in series to gain a higher output?, or is it possible, to do electrolysis, with 3 chargers, all going at 12v 500ma, all elelectrolysing theyre own electrodes in the same solution? meaning ill have 6 electroded in there, 3 anodes, 3 cathodes.
But if you use AC, then in a cycle the electrolyte would be reduced in the first half and then oxidised in the next half of the cycle, leaving the electrolyte as it is.
But please verify.
If you don't know what you're doing with electricity, I should think it a very bad idea to be playing with "large amounts of potassium and sodium chlorate and perchlorate" - Leave it alone, it'll be dangerous.
L
Depending exactly on the application (I can't be specific) it may help or hinder that the current fluctuates -- this can cause the expected splitting reaction, but the reverse current in quick succession can re-absorb the electrons just emitted and rejoin some of the molecules. I'm sure we have a pro around here who can speak to it more clearly.
