whats the best way to sharpen a knex rod?
i want to sharpen a knex rod but it never ends up looking like for example gorkems rod in his video i tried sanding it down with a gear box and a drill to make it spin fast but the rod melts when it spins to fast so how can i sharpen a knex rod more effectivley
Dec 18, 2010. 2:26 AMshieldsam says:
use a lathe. extra fine, precision super-sharp rods.
Nov 11, 2010. 11:45 AMknexinventer says:
pencil sharpener
Oct 7, 2010. 10:54 AMshieldsam says:
use a rough file
Jan 22, 2010. 11:21 AMPrranavan says:
i use pencil sharpener but i need to get an electric one coz pencil sharpeners do the job but it hurts ur hand a lot
Jan 4, 2010. 3:30 AM~KGB~ says:
pencil sharpner!
Aug 12, 2009. 7:45 AMgeodez says:
first i pencil-sharpen it (electrical not manual, manual sharpeners just aren't the right design, the blades may break) then i place it in a drill and spin it while grinding the head on a crank grindstone to get the pointy tip, it is very sharp and dangerous, have fun!
Aug 5, 2009. 2:50 AMnutty guy says:
me I use a sharpener to start because if you just use the sharpener you will make it blunt then I carve away with a knife to make it sharp and when the rod gets blunt I re sharpen it with knife but be careful
Aug 3, 2009. 6:38 PMknexsniper1 says:
i sharpen the knex rods in several ways. 1. use a pencil sharpener, the electric kind work better 2. use a filer for nails to erode the edges 3. use sandpaper 4 use an exacto-knife 5. very dangerous, (not reccomended) use an actual knife. hope this helps :) - Ksp
Aug 2, 2009. 6:56 AMDJ Radio says:
pencil sharpener is better than using a knife, the point is sharper, and its safer.
Jul 31, 2009. 8:16 PMKiller~SafeCracker says:
There are several different ways. I use a pencil sharpener but I have a few that are done on a grinder (they turn out like gorkems). I have also used a sharp knife and a file. I wouldn't use the knife because they are not as safe and the pencil sharpener worked better. So in the end I would use a grinder, file, or pencil sharpener. Hope this helps. K~SC
Jul 31, 2009. 1:36 PMYerboogieman says:
Pencil sharpener or Utility knife.
Jul 31, 2009. 1:17 PMlemonie says:
Use a sharp knife, like you were sharpening a pencil. It's a bit of a skill, but it's not that hard to learn. L
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
