where do I find in the internet about the Swing-Mark automatic valve for resturants and bars.?
Swing-Mark valve is a automatic flow chemical dispensing mixing valve, that works with the flow of water going through the valve. dispensing detergent and sanitizer chemical to each sink at a pre mix of water and chemical controled by the valve. Depending on the type of metering valve it has.
Resturant and bar owners real perfer these valves because they automaticly always have a E P A regulated mixture of sanitizer per water, to wash and sanitize glasses and cups.
Or any info on similar valves.    THANK YOU
f1cam (author) says: Feb 17, 2010. 6:02 PM
From Chem-mark, they sell them to you and they are not cheap, but they do not want to tell you to much about them because it is a very simple system and I know I can make them better and cheaper.
Thier parts to repair them are not cheap eather, they seem to clam up when you ask about them as far as technical questions.
BarPro in reply to f1camFeb 17, 2010. 11:32 PM
Where are you located? There's not many companies with chemical dispensers for your bar sink. We offer a brass/stainless steel dispenser with our sanitizer and soap. If you are interested check our website... www.ThoroLA.com
seandogue says: Feb 17, 2010. 9:32 AM
Does it help with washing spam off the plate? I find that the Swing-Mark automatic valve is a poor product for washing spam off things. It always seems to leave a thin layer of spam. You know what spam is right? Anyway, while thick spam is obvious, thinly veiled spam is spam nonetheless.
Re-design in reply to seandogueFeb 17, 2010. 9:38 AM
That almost went right over my head.
seandogue in reply to Re-designFeb 17, 2010. 10:29 AM
I have a feeling the author will understand it immediately.
RavingMadStudios in reply to seandogueFeb 17, 2010. 12:06 PM
I find that to most effectively remove spam, a flag can be used almost like a washcloth. Wipes the spam right off.
seandogue in reply to RavingMadStudiosFeb 17, 2010. 12:18 PM
Ah...Yes, I 've tried that, with limited success. The flags available don't seem to be very effective here though, unless the coating is particularily obvious.Maybe it's the fabric they provide at instructables... I did use that avenue, but figured I'd let the author know about the limitations of his product directly anyway, just so he knows that people are looking out for his interests..
RavingMadStudios in reply to seandogueFeb 17, 2010. 10:14 PM
Hmm... seems like the flag has not been as effective recently as one might hope. Case in point, I am able to post this reply several hours after application of the flag to the problem. Problem is still here.
lemonie says: Feb 17, 2010. 11:06 AM
Where did you hear about it in the first place?
L
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
