3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
why do all batteries require different charging?
i mean like the difference between nimh, lead-acid, lithium-ion, and recently even alkaline.
how do they each charge, and why is there a danger of exploding batteries (like lithium-ion) when charged the wrong way.
is it like charging in fast on/off cycles, high volt low amp (or the other way around) or messing with anything else?
Apr 19, 2010. 9:03 AMsteveastrouk says:
The chemistry underlying each of the batteries you mention is radically different, so the charging cycle you need for them is also radically different, and particularly important the detection of FULL is different. If you don't detect "full" properly in a LI-po battery, it can overheat and explode, if you discharge it too fast it can overheat, and explode.
Do some Googling.
Apr 19, 2010. 9:49 AMsteveastrouk says:
The key ways are at a constant current, or at a constant voltage (with a current limit).  You don't usually modulate the charging current.
Lead acids are usually charged at constant voltage,
Nimh and Nicad at constant current.
The RATE you charge at is pretty critical to battery life - fast charging ages everything but some LiPo and Lead acids for example much more  quickly.
Steve
Apr 20, 2010. 5:48 AMsteveastrouk says:
Lithium don't suffer from memory effects, but they still have a lifetime.
Steve
Apr 20, 2010. 10:38 AMsteveastrouk says:
That's right, if they don't have the right protection they can go into thermal runaway. You HAVE to terminate charging at something like 4.30 Volts per cell OR lithium metal begins to plate out, and the cathode releases oxygen - yummy.
I would buy a lithium charger circuit "off the shelf" (Maxim, Linear Technology, Analog Devices etc etc) rather than roll my own.
Steve
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
