why does my amp automaticly turn the protect on when i turn it on?
null
lemonie8 years ago
Does it happen with nothing plugged into it, what is plugged into it right now? L
i tried just conecting power to it and it still just turns the protect on
Thanks for adding that. See any other comments here.
And see if this is at all relevant?
http://www.caraudiohelp.com/newsletter/amp_protection_mode.htm
L
NachoMahma8 years ago
. Depending on the amp, this could be caused by a lot of things. High temperature detected, load impedance too low, &c. . If disconnecting the speakers and setting all volumes at minimum won't clear the fault, you'll probably have to do some electronic work (eg, replace an RTD or T/C). . Hard to tell without knowing more about the equipment. . If you don't have the users manual, see if you can find it online.
