loading
why is my solar garden light flashing?
hey guys
i brought a solar garden light the other day so i would have soft light on my table when playing video games in the dark mostly so i can see my drink and food an not have to get up turn the light on or fumble around potentially making a mess. it worked fine then i had an idea to boost the "cool" factor change the LED out for a red one so i did and now it lasts a hour actually 45 minutes to an hour then it starts to flash five seconds on 5 seconds after another hour it'll be 5 seconds on 180 seconds off  i think roughly an ad break on New Zealand television.
is it the 1.2v nicd 600mAh battery?
i thought it should just be brighter seeing as the white one should be rated at 3.5v 20mA?
and the red at 2.0v or less?
also
can i replace the battery with a more powerful one without having to modify the actual electronics?
thank you
rickharris6 years ago
These supply very little current and use a form of joule thief to make it large enough to light the LED. ,P. More than likely the red LED is draining the battery too fast and cause the joule thief to cut in and out causing the flashing.
The LEds are carefully matched to the circuit/battery combination. Although rated at 20 mA I doubt the original LED was drawing that amount of current.
Hey, your a different colour !
suesolar5 years ago
That's a good idea. you are a talent. I work in a solar light company, It'a good opportunity to act your idea. Do you want to achieve it? I can support you solar light . let's make it together. it's my website: www.chinasolarlight.net. you can mail me or leave message.
lemonie6 years ago
Next thing that happens is it stops working altogether.
As you go from red to blue to white to UV, the voltage across the LED goes up. If you've replaced something with red you've dropped the voltage and it's shifting more current.
Put e.g. sweet-wrappers on the thing if you want red or add a resistor.
L
Scotty3000 (author)  lemonie6 years ago
yes, it doesn't work at all now with the original LED only about 10minutes after a full sunny day. the red LED goes all the time now just really dim
I am not clairvoyant, I just know a few things...
L
acidbass6 years ago
you switched the led with a more energy consuming one
