3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
will an sts transistor work with an led cube powered by arduino?
sts 1979 f2 transistors
I know I'm supposed to use npn ,but I have sts 1979 f2 transistors and sto 1862 te3 transistors on hand.
Jul 5, 2010. 11:59 PMsteveastrouk says:
No, you can't use PNP without some major re-design work. Steve
Jul 6, 2010. 10:48 AMsteveastrouk says:
They are biased differently. Here're two transistors, the left one is PNP, the right, NPN.
How to get current to flow in the resistor ? Assume the top rail is +V and the bottom is a ground.
In the left one, GROUNDING the base turns on Q1
In the right, raising the base ABOVE ground turns on Q2
Note that the COLLECTOR of Q1 points to ground, the EMITTER ofQ2 does.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
