will putting five volt regulators in parallel reduce the strain on them?
5
answers
Answer it!
Look at the datasheet for a National Semiconductor 78xx series regulator and you'll find a circuit for increasing the current output from a single regulator beyond its secs using a power transistor.
A Google search for current balancing circuit brings up a couple of useful schematics on the first page. They may be adaptable to your needs (treat each of your regulators as one of the "LED chains" in the example).
I might just try it... I mean, I bought a bunch of regulators because it was cheaper to buy a package of ten than just to get one. :P
The regulators, however, take whatever current is pushed into them (technically, whatever the load pulls through), and just convert the voltage from input to output. Since you've got a single load on the parallelized output side of the regulators, the current path is determined by the relative resistances.
However, I did make an incorrect statement, and rather misleadingly :-( By Ampere's law, the current will divide across the parallel branches in inverse proportion to the resistances. It is only for the case of one parallel branch having much lower resistance than the others (e.g., you in a bathtub along with your favorite resistive appliance) that the current will seem to "switch paths."
So long as none of the currents exceed the regulator's rating, you could have a stable situation. If you're close to the limit, though, unbalanced branching could push one regulator over the top, causing a cascade failure.
