3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
yet another toshiba laptop question.?
I have been using my Toshiba Portege M300 for 4 years now. Normally the fan is quite smooth and quiet, but it speeds up if the laptop gets hotter. This evening I thought the fan had a slightly different tone to it and was louder. Also, the speed didn't seem consistent; it seemed to move up and down randomly.
Should I be concerned?
Nov 23, 2009. 8:38 AMfrollard says:
The fan is dying - specifically the bearing that supports the fan.
Guessing it mostly 'buzzes' as the new sound, and the speed sporadically changes 'fast and slow' randomly - thats the offset bearing falling in and out of harmonic sync with the spindle.
It might be possible to replace the fan - if it's not a specific unit.  Trouble is laptops 'near the cpu' are often notoriously difficult to disassemble/reassemble for laymen...  Look for a guide to disassemble your laptop to find type of fan is needed for replacement.
Nov 23, 2009. 2:12 PMfrollard says:
Not your SPECIFIC model, but I bet the 200-400 series are 'similar'...
http://repair4laptop.org/disassembly_toshiba.html
Either way, you need the bottom off, and maybe (rarely) access it from the keyboard side.
Nov 23, 2009. 2:15 PMfrollard says:
quote from another guide I found (400 series):
"To change the fan you will need to remove the motherboard"
fuuuuuuuuuuun.  Just document what you take out from where, and what order to put it back together.
Nov 24, 2009. 6:19 AMfrollard says:
Sorry I couldn't be of more specific help...
"no bearing" - it might not have a ball bearing, but the fan must spin on something - even if its just a plain axle - THAT is wearing out :(
Nov 27, 2009. 11:42 AMtragicallyhip says:
Neivaden is correct , unscrew the single panel covering the CPU/heatsink,Remove the screws holding the cpu/heatsink and remove gently.The fan assembly is not designed to be removed and serviced as it,s a replace only item,but with a little patience it can be . Once the fan assembly has been broken down into it's constituent pieces a little dab of a light weight Molly grease on the fan's axle will do the trick.Re assemble everything and your good to go,I would not expect this Hack to be a permanent fix but it will buy you time to find a replacement fan.Im not guessing about this as I had to perform this hack on my own toshiba.
Nov 23, 2009. 1:35 PMneivadan says:
yes u should because the longer u wait the more the problem gets worser and trust me don't ignore ti or urlap top is a goner.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
