loading
12V Monitor LCD display
I'm looking for a 12V display to monitor 12V as it changes. And display it in .1 increments. Small as possible. Can anyone point me to something cheap?
1-10 of 13Next »
Goodhart8 years ago
LONG time ago, I made one with 2 v increments, using standard rectangular LEDS as an indicator (6 of them), and I believe the project involved using 2 Decade counters, but I don't remember much else about it. I will have to look to see what I can find...
fasterthanyours (author)  Goodhart8 years ago
After some searching I found out that what I need is an LCD, not an LED display. Sounds like what I'm looking for, but I really need to see the voltage in the 1/10th or 1/100th increments. Basically what I'm wanting is to setup a reiostat(sp) that regulates the voltage going into the LCD, the LCD displays the voltage going to my monitor device, the device is making changes to other things based on the voltage. I need the voltage to be visual so I can demonstrate that to people. Thanks.
is it possible to take a small lcd screen and light / make dark single pixels in it (as in X Y) ? maybe you can use such screen + 7 bit or better ADC (8 bit are common) and some demuxes
fasterthanyours (author)  110100101108 years ago
Thanks...I'm not electrical engineer.
I was kind of hoping some one had a lead on what I'm looking for.
This seems to be the most promising and I have contacted them.
http://www.alibaba.com/product-gs/217276240/LCD_battery_monitor_for_2S_to.html
Not sure if their display does greater than single digit voltages.
what i think of is like a download bar that goes between 0 - 100 without actual numbers displayed
Nah i need the numbers because I need to indicate to my customers that said voltage coming from this accessory is 11.8 so my equipment sends out 12.2 to another accessory which makes it perform a certain operation based on that 12.2 voltage.
then use the circuit from a multimeter
Man, I don't know how I missed that thanks! I've got 6 of those in the garage, I'll just use those! Seriously though. I'm building what amounts to a diagram of a 12 volt system with many accessories and I need to display voltages for many of these items all at once. So using a multimeter or multiple is neither functional nor professional looking.
you can disassemble the circuit and screen from the box you can build a circuit that switches the display between the sources
Hmm..Maybe..I'm still hoping there's something out there already made to do it. Stinger Electronics makes one, but it's $20 or $30, however they look really good. I know I can find those pocket multimeters for cheap and do what you suggested. However, I'm still open to other suggestions.
1-10 of 13Next »
