12v to 5v how do i do this
35
comments
Add Comment
Example:
USB 5 volts that provides 9 volts from the output of the circuit?
I wouldn't need high current not more than half an amp
secondly,i'm in a process building obstacles avoidance robot with multiple sensor, do you guys have any command to to be install in PIC fro my robot...
Buy one 12 volt car lighter charger that has 5volt out put 1AMP output
Wire it all up the tip is the +
and the neck part is the negative
Note of the polarity or you'll break the car charger
WORKS FOR ME ALL THE TIME
And it lasted a whole 3 and a bit years!!!
Speaking of which, what do you need the voltage regulator that converts 12v to 5v for?
Go do a basic electrical course.
And... then by the time you get the understanding, on "HOW" to actually ASK this question properly, you will have enough knowledge to be able to answer it yourself.
Here is a great website with some electrical text books that you can download.
http://www.allaboutcircuits.com/
As a hint.... the WORST way to learn anything, is to ask other people to do your thinking for you.
you need magnetic wire and some 1 inch pvc.
take the pvc and wrap the magnetic wire around it 200 times. this is the primary.
take a new piece and wrap the magnetic wire around it 100 times.
connect the two pipes by pvc elbows.
|-o-o-o-o-o-o-o-o-|========== - input
|-o-o-o-o------------|========== - output
this should give you six volts if built properly.
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
