3X Gasoline Engines Sniff Vapors and Burn Water
Sounds ridiculous doesn’t it? How can water possibly be turned into a useful fuel by just burning it? Sure we can use hydrolysis to separate water into its hydrogen and oxygen gases, and then burn the hydrogen gas as fuel, but that’s not what I’m talking about. Believe it or not, jet engines do it, they have used water to enhance engine thrust, so why not have IC-engines do the same thing?
There’s a catch here, since only vapo-engines (  http://goo.gl/QQ42k ) are capable of performing this trick successfully, they must first be introduced into the design mix. Since IC-vapo-engines burn very effectively they run hot, and water would be used as a better alternative than injecting extra wasteful fuel to cool down the engine as is done in today’s engine to prevent knocking. Why don’t we just inject water in today’s engines you ask?  Because they run so poorly already, that the water would extinguish the IC-combustion process. In technical jargon this is known as the ability for an engine to burn lean with an air-to-fuel ratio greater than ~15. Today’s engines can’t sustain a leaner combustion than ~22  without extinguishing themselves. By adding water droplets we further increase this ratio to unsustainable conditions. Unfortunately, this wasteful, richer burning keeps the engine running better by keeping the fuel cooler. In contrast, our vapo-engine is capable of burning unbelievably lean ratios of ~30+. Lean combustion means almost no pollutants and virtually green combustion exhaust products of only CO2 and water. No catalytic converters necessary here, as opposed to running today’s rich engines with their unavoidable polluting exhaust emissions and heavy reliance on catalytic converters.
So the irony here is that since IC-engines already run ratty, let’s waste a little more fuel and run richer just to cool down the engine. This prevents engine knocking (the dieseling of an engine due to unwanted, poorly timed, premature combustion) which occurs from the pitiful amount of fuel that does vaporize and burn correctly. Sadly, engineers have cleverly learned to waste fuel for the sole purpose of keeping our IC-engines cool, above and beyond the engine’s normal water cooling system. It gets even better, as the richer the engine runs the more we need to rely on expensive catalytic converters to keep exhaust emissions in check!
 Vapo-engines also require cooling, even more than today’s engines, but their advantage is the capability to burn very lean. So instead of ridiculously injecting extra fuel to cool them, like today’s engines, we inject water droplets mixed in with the injected fuel vapor. The water droplets perform three functions; 1) they reduce excess fuel consumption, 2) they cool the engine walls to prevent pre-ignition and knocking which provides better combustion, and 3) they enhance the fuel-vapor detonation force created on the piston from the expanding superheated steam which further helps engine performance. So in a way we are burning the water to generate steam power like a locomotive.
1-10 of 20Next »
lemonie5 years ago
What is the purpose of this post?
You've spent a lot of text talking about something, but I can't see why.
L
RT-101 (author)  lemonie5 years ago
Fair question.
I’m trying to keep the vapo-engine topic alive and interesting by using sound-bites to address its concept. Having previously been accused of using too many words on my forum topics, I'm making mid-course corrections.
As no one challenged the high temperatures generated by Vapos (since it is capable of very lean combustion without wasting fuel that others use just for cooling “not power”), I wanted it recognized and then dealt with. Vapos go all out in needing every bit of technology we have today to make it work properly, that’s why you’re not driving in one now!
lemonie RT-1015 years ago
Have you got some testing (yourself) in mind, or are you asking for people with engines to experiment?
And out of interest, have you sent any letters/emails to engine-manufacturers?
L
1) SELF TESTING: Yes eventually I intend to modify small engines the size of lawnmowers into vapo-engines and test them, but no water additives yet. The demo would be intended to shame Detroit. Lots of folks are already applying the vapo concept (without burning water) on a small scale on Youtube, but without any real engineering design behind it, just tinkering. Still, some are starting to get favorable results just from tinkering, which should encourage others, start shaming Detroit, and wake up the government. DIY folks are clearly starting to prove the potential of vapo-engines, and I love it!
2) ENGINE-MANUFACTURERS: Engine manufacturers have been aware of this concept for quite awhile (probably over 50-years), they just don't want YOU to know about it. If they can make money selling the "crap" they have now, why fix it unless they seriously get pressured by the government and the public. That's why this blog exists! Remember though, it will take some serious engineering design efforts to make it happen correctly!
1) I thought that Detroit had suffered a major decline since it was Christened "Mo-town"?
2) In Europe, because of high fuel-taxes, engine manufacturers have been pushing fuel-efficiency for a long time.
L
Kiteman lemonie5 years ago
I saw a car advert here today, boasting about fuel efficiencies of 40mph, for open road driving, as if it was amazing advance in engine technology.
In the UK, that was typical efficiency 20+ years ago.
My current car does 60mph on urban cycle!
lemonie Kiteman5 years ago
I watched one of the most bloody-awful corporate videos today. I made gestures with my fingers at the screen and pointed them down my throat. If I was an angry person I would have been very cross indeed.
The product it's self is fundamentally good-gameplay and ought not to need this crap.
L
what is an urban cycle? is that like the spin cycle on the washing machine?
It's what the EPA calls "city driving" vs. "highway driving." Those wacky Brits always have different words ;->
We call it "urban cycle" be because we don't apply the title of "city" to populations of three hundred...
1-10 of 20Next »
