3w common anode RGB LED circuit?
Does anyone have a link to a circuit diagram for a common anode led? Here are the specs:
- Red: 2.5V ~ 3.0V, 350mA
- Green: 3.2V ~ 3.8V, 350mA
- Blue: 3.2V ~ 3.8V, 350mA
Soooo, either a circuit that can sink current (I believe that is the correct terminology) or some way to isolate power between the 3 colors would be much appreciated.
Here is a link to the led I have: http://www.dealextreme.com/details.dx/sku.4530
8
comments
Add Comment
That's not a description of a common anode in the case of LEDs. It's not possible to use separate supplies for each component LED if the anodes are connected.
Hmm, well, I built one each of the power supply in steps 10-11 here for each color: http://www.instructables.com/id/Circuits-for-using-High-Power-LED_s/
If I connect each driver to each color and then to the same power source, turning one color up turns them all up. If I connect them to separate power sources they work individually. *shrug* I understand why - there's nothing to prevent the current from traveling through the other two leds, but don't know how to change it.
Are you saying that I should be using only one voltage regulator and then different resistors/current limiting methods for each led?
Thanks for the sugestions.
I'm sure an FET would work, too. But you'll need some type of transistor switching, since the power requirements are high.
Regarding:
but I have to use totally isolated power supplies (i.e. one separate battery for each color).
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
