555 TImer/Chip Help
I need your help people of Insturctables. I am working on an project, and I need to make a circuit whit a 555 timer/chip so that it makes,for example, an LED light up in every 2 second. I mean when it turns on, it needs to be on for 2seconds than off for 2 second...loop. ON(2 seconds)___OFF(2 seconds)___ON(2 seconds)___OFF(2 seconds)___LOOP I need the output to be 12V. Actually I need it for a fan to turn on and off(the fan runs on 12 volts) Can you help me make a circuit for this, what value of the resistors and capacitors do I need... It would be grate if some one could make a schematic of the circuit in Eagle, or so... If I make an Instructables about my project I will surely mention who helped me realize my idea! Thank you all! -Stanislav
12 comments
Oct 21, 2008. 6:27 PM11010010110 says:
for 2 sec / 2 sec period pick C and X so that C (in uF) * X (in K) = 3000
as transistor allmost any NPN transistor that can take the current of the fan is ok. use a resistor at the base (B) so that 12 V / resistor is less (but not too much less) than max base current of the transistor. its like few K for small transistors and few hundred ohm for larger ones
the capacitor at the left is there for filtering but it may work ok without one
Oct 22, 2008. 7:05 AMgmoon says:
I wouldn't use that circuit without a protection diode for the inductive load (the fan.)
Transistor switches, scroll down for protection diode...
Oct 22, 2008. 4:24 AM11010010110 says:
C and X examples
100 uF 30 K
1 uF 3000 K
33 uF 90 K
4.7 uF 680 K
if C * X is less than 3000 you get shorter time and the other way (not too critical)
use X atleast 1 K and max few thousand K (above that may have stability issues). with higher X the circuit takes less current and is more efficient
circle is pin 1
ground blue
12 V red
Oct 21, 2008. 1:38 PMguyfrom7up says:
make sure you use an LM555 they can source up to 200mA if your fan is more than that you need a transistor for a 50% duty cycle you will need to use a diode. I havn't used 555's in a while, so yeah...
Oct 21, 2008. 8:46 AMwestfw says:
You can use the schematic and pcb from my Eagle instructables
For equal on/off times, R1 should be as small as possible (about 1k ohms.) For approximately 2 seconds on and off, you can use R1=1K, R2=300k, C=10uF. There are numerous "555 calculator" apps on the net...
Oct 21, 2008. 12:59 PMwestfw says:
That's just it. My EAGLE tutorials use a 555 flasher circuit as their example project, so the schematic tutorial has the schematic you want. You may be able to leave out part of the circuit, depending on how much power your fan uses, but the R1/R2/C designators match up WITH THAT SCHEMATIC (ok, "C" should have been "C2") (It doesn't explain the schematic; many other sites do that...)
Oct 21, 2008. 9:30 AMwhatsisface says:
It would also be beneficial to use a transistor or a FET to drive the motor, as they will provide a higher current.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
