loading
5v relay module with tv usb
Hello there!
I'm sorry if someone already asked this question but I can't find it! I would like to connect 2m led strip to my tv usb so it turns on and off with tv. Can I use this kind of relay ( http://www.ebay.com/itm/5V-1-Channel-Relay-Module-H-L-Level-Triger-with-Optocoupler-for-Arduino-Raspberr-/390865576871?pt=LH_DefaultDomain_0&hash=item5b016763a7 ) to do it?
Thank you in advance!
Looks like it will work, but its overkill. A SMALL relay and a diode on the power pins on the uSB would be fine.
tosho82 (author)  steveastrouk2 years ago
Thank you for the answer but I don't understand what do you mean by "overkill"? English is not my native language. Could you tell me what relay should I use?
Just find a little 5V coil relay in your local market, no need for opto isolation. Look for a relay with a coil that takes <50mA to drive it, like this one.
Connect the coil, with a diode across it, Diode marked end to the USB +, diode unmarked end to the USB -.
Try finding a relay like this
http://uk.rs-online.com/web/p/non-latching-relays/...
The coil is 5V, the contacts will handle 2A.
I can't tell from your profile you are not a native speaker - that's why your profile asks where you are in the world.
Thanks for quick and detailed answer Steve!
