9W Fluorescent U-Tube Bulb w/ 6V 4Ah Battery
Hi Guys!
I would like to create a sort of emergency light with the following...
9watt fluorescent u-tube bulb
6volts 4Ah sealed lead-acid battery
HP AC Power adapter (input : 100-240v | output : +32volts 625mA
I'm not really good with electronics... please be so kind with me :)...  I'm wondering what will be the things needed here to create the following
battery charger and
to power up the 9watt bulb
Thanks a lot in advance
I think there is an instructable about using low voltage with florescent lamp, If not you can find details on the net.
You should start reading up on how a florescent lamp works, what a ballast is and why it's needed. Building a battery powered florescent lamp may not be a good project for the novice. You would have to design and build a ballast that can run off your DC voltages. Which would require you to build a boost converter.
Besides that i had a similar idea last night but wanting to use "dead" CFL bulbs. Often it's the electronics in the bulb that go bad before the tube does. But i found it will be more involved then i had hoped and i wouldn't have time to finish the project and instructable in time for the contests i wanted to enter. Oh well.
acl_20032003 (author)  mpilchfamily3 years ago
Thanks for the honest response.
Here's the reference for the 9watt fluorescent u-tube bulb
http://ecx.images-amazon.com/images/I/31wLRXcQgVL....
That's the kind of bulb you see on emergency lights. And here's the products you will see in the market...
http://www.belmontdepot.com/images/6024000000406.j...
Hope you could enlighten me about it.
thanks
