3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Help needed to upgrade wheels on walker for all-terrain ?
I've been trying to source a rim / hub  for my e-walker project , and so far havent been succesful  in finding the exact measurments I need
7.5 " wheel / 46 mm width with 9- 10mm bearing ( SEE BELOW )
http://www.mcmaster.com/#ball-and-rolle ... gs/=9i3dx1
The spacer inside the wheel based on my measurements is 2.7 mm in length and 13 mm in diameter ( outside )
Any way , it seems the best match I can find for hub , tire so far is one of those wheels used on those razor electric scooters  here  though I do not see any bore sizes for any of them, in spite of being told there are after emailing them that its up there ( you can see for yourelf if you like )
So instead, I did websearch on the model of the scooter that correlated with the sorta wheel specs that might work - like e100 razor  and found 8mm mentioned a few times , which I assumed might be the correct diameter of the axel / bore size i need. ( I have also asked on scooter forum to confirm this )
8 mm however is too small to fit my own  knee walker mobility device , so I was wondering - to cut a long story short  - if there is any way I can enlarge the hole in the bearings that might be realtively easy i.e. without paying someone else ( assuming this could be done easily ) or
having to buy a rim with a bigger bore and using some sort of hub ring to make u the difference ( perhaps a bad idea for hun motor )
Again , if any one has any suggestion they willing to share I'd be more than greateful for your ideas and badly needed advice  :)
thanks once again.
hele
12 comments
Nov 4, 2010. 11:23 AMcaitlinsdad says:
Does this site help any for finding replacement wheels? I guess you could call them and tell them what model/kind of walker you have and they may be able to help?  Is that the problem you have, the wheel bearings are shot and you need to replace the wheels?  Going about to hack the walker may lead to other problems.
I guess I can see the difficulty from this situation.
Nov 4, 2010. 5:02 PMcaitlinsdad says:
May I suggest you edit this forum topic to "Help needed to upgrade wheels on walker for all-terrain" or similar? I think there are a wealth of people who do similar mods for bikes, bmx, landsurfing, cars, etc that will be able to chime in with their expertise.
This may be extreme http://www.wheelchairdriver.com/power-wheelchair-off-road.htm but there have been projects to adapt bicycles to motor drive and the technical problems to resolve are along the same lines.
Nov 4, 2010. 6:06 AMNachoMahma says:
.  No. :(  Most of the bearing parts are made from hardened steel, which is almost impossible for a DIYer to work with.
.  You should be able to find a bearing with the proper bore and other dimensions. If you can give us the dimensions (bore, OD, width), we may be able to help find what you need.
Nov 4, 2010. 10:18 AMNachoMahma says:
.  It's only $6.79 (plus shipping), so I'd give it a try.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
