loading
Accelerator in a bowl
I want to help my kid explain particle accelerator with this project; I think I get the conductive ball
and positive/negative strips. What do I use to get "high powered dc current"? any suggestions ?
I would like this to be self contained i.e. not plugged in.
Thanks
http://www.symmetrymagazine.org/breaking/2008/03/26/accelerator-in-a-bowl/
kelseymh8 years ago
In addition to the "electrostatic cyclotron" you posted, you could also build a mechanical linear accelerator out of small magnets and steel balls. User "whatsisface" posted a link in the parallel discussion I started.
kelseymh8 years ago
The positive and negative strips are basically just copper tape (you can buy it at a craft store, or from McMaster-Carr. Dr. Johnson says (in an e-mail to me), that he pulled the power supply from a "negative ion generator" to use for this project. The supply is fully potted, so all you need do is connect the 15 kV output leads. If you haven't worked with high voltage before, do some research first. It can bite! It will need to be plugged in via a wall-wart, or you could probably rig up some good 12V lantern batteries to a cord cut off a wall-wart. Note, Dr. Johnson also said that the bowl was a custom acrylic job he had made for the project. I'm going to discuss that with him some more; I wonder if a good quality pyrex mixing bowl would work, but I don't know.
kelseymh8 years ago
Somebody (you?) moved this topic over to Science. There's also been some discussion in the verision I created, just reporting on that very nice demo.
kelseymh8 years ago
Would you consider re-posting this in the Science forum? "Feedback" is meant to provide comments to the I'bles Staff regarding the operation of the site. You'll get more and better results if you post to a topically appropriate forum.
