loading
Adj. Temp Sensor
I am looking for a 12V adjustable tempurature sensor that will provide a trigger output when the temp exceeds the setting. Can anyone help ?
1-10 of 16Next »
Goodhart9 years ago
What kind of sensitivity are you speaking of, a degree, 10ths of a degree, 20 degrees etc? Should it be electro-mechanical like a bimetal thermostat or like Temp sensor ic analog or digital ?
daveyandgolie (author)  Goodhart9 years ago
Looking for something with a digital display that reads in degrees (maybe with one decial point)
You didn't mention digital display in your original post. I would suggest you buy a ready made digital thermometer with a temperature alarm function. These devices are very cheap now, and you can hack the alarm output if you need it to trigger something. Cheers, Pat. Pending
. That sounds like the best idea, so far. I bought a Sharp SPC315 for ~20$US (at Wal-Mart) a while back. Came with a wireless sensor. Has all sorts of calendar/time/temp functions (even moon phase).
Hi NachoMahma, seems ages since I bumped into you on a thread:)
Much of the cheap electronic stuff you can buy today is cheaper than the price of the individual parts. Consequently, there is little point in reinventing the wheel and building it yourself, as you wont be saving any money.
Cheers,
Pat. Pending
Unless you just want to put something together for learning purposes ;-)
Well, here is a National Semiconductor spec sheet: NSC White Paper
And here is an example of one of the products: LM335 Precision Temp Sensor
If you are interfacing to a PC, here is another option <link>
True, a properly constructed thermistor circuit could work too.
you could do what I said and use a volt meter and calibrate it
guyfrom7up9 years ago
what you probably need is a microcntroller with an analog to digital converter, and a thermistor. Or an alternative aproach without a microcontroller would be using a thermistor, potentiometer, and a relay
1-10 of 16Next »
