COMMUNITY : FORUMS : SQUARE PEGS
Airsoft minigun
Here is an awesome easy airsoft gun I built from Nighthawkinlight. link:http:// http://www.instructables.com/id/How-to-Make-a-Full-Auto-Airsoft-Minigun-Halo-Insp/ Highly recomended!!!! I built it for about 30$. My plan i am working on right now is to use the same compressed air method to build a paintball pistol with a 8 cap mag, its working out great so far. Here are the stats for the gun pictured.
PROS
Compressed air powered!!! (to me this is awesome so i dont have to spend $ on Co2, or a battery that you need to charge)
great range 250ft!
lighter than it looks
high rate of fire 50/ sec
sturdy design
very accurate
CONS
uses ammo up quickly
kinda large
takes a while to pump
PLZ RATE AND COMMENT PLZ
boredom99 says: Sep 3, 2011. 7:16 PM
Hi Im a little confused as to how the barrel goes in. Do you just put the aluminum barrel on the edge of the reservoir where the two end caps are glued oppositely together? And what would you say the fps on this is?
Football viking boy (author) says: Sep 5, 2011. 10:35 AM
Hello, on pic 2 to the right of the handle in the center of the gun, you see some tape around two end caps, the barrel fits in there and then in pic 4 i taped the barrel so it wouldn't move
FPS depends on how much you pump it up but usually around 300-400
knexxenk says: Aug 31, 2011. 7:08 PM
I built one but instead of an air tank I attached it directly to the compressor!!!
130 PSI = : ) heck yeah!!!!!!!!!!!!!!
Football viking boy (author) says: Sep 1, 2011. 10:09 AM
cool! =D
NightHawkInLight says: Aug 30, 2011. 2:46 PM
Great job! Glad to see you're having fun with one of my projects. It would be cool to see a video!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
