Alternative to keyboard
On top is a joystick like an NES joystick. It registers 8 different directions: up, down, left, right, and the in-betweens of those and is controlled by the thumb. Then there are 4 buttons, one for each finger. The joystick replaces the trackpad of a laptop and hopefully is also 'clickable'  to act as a 'left click button. I'm not sure what would do the right click button.
Combinations of button presses and joystick directions would replace the keys on a keyboard.
I only have the use of my right hand. I initially thought of this as a device for handicapped people like myself, but it would also be good for people lying in bed. The concept maybe could be made into a cell phone case with physical buttons that would allow people to text without looking at their phones.
The device is a lot like the nintendo wi remote, but not quite. Maybe a wii remote could be hacked to make a prototype. I wouldn't know how to do that and I wouldn't know how to program it, that's why I'm posting, to see if someone could tell me what kind of skills/knowledge would be needed to make this idea happen. Any suggestions or offers to help are welcome. Thank you!
1-10 of 22Next »
Glumgad15 days ago
About keyboard layout
I have an alternative solution. It is based on traditional keyboard.
Do you know that it is possible to change keyboard layout? It means that you can make any key calls any command.
My suggestion is.
1. Find out which keys of the standard keyboard are convenient for one-hand use. For example, you can keep your pointer finger on F key and your ring finger on J key. But it is just an example. What keys are easy to operate by one hand? We will name them "active keys".
2. Then we will make an alternative layout to make the active keys call alternative commands. For example to make key F call command Q.
3. You will print stickers for all active keys. Each sticker will have two (or more) letters. One letter for the traditional layout, another for the alternative one.
How does it work?
If you need to type a letter which is easy to reach, you switch layout to "normal" and type.
If you need to type a letter which is difficult to reach, you switch layout to "alternative" and type.
Also, you may use a short press for normal and a long press the alternative layout.
Glumgad Glumgad15 days ago
I mean smth like that http://half-qwerty.com/ But it costs too much!
I am sure it is no difficult to convert ordinary keyboard to the "half-qwerty" by software.
A bit more google and I found a way how to convert QWERTY to one-hand keyboard http://www.frogpad.com/
Glumgad16 days ago
I think it is a good idea for an Open Source project.
Also, I see two main tasks:
Hardware+software prototyping and ergonomic prototyping. We can do them separately.
I believe, the ergonomic prototyping is a key task. The project will have a sense if we could imagine a tool which could be more convenient than the traditional keyboard.
avocadostains (author)  Glumgad15 days ago
The device could help people with poor vision or limited finger mobility/arthritis. Think of how typing for extended peiods of time can lead to pain/carpal tunnel.
Assuming it were easy enough to learn, it may also appeal to 'hunt and peck' typists that never learned to touch type. I learned touch typing before I lost the use of my left hand and just the knowledge of knowing where each letter key is on the keyboard lets me still type at least as fast or faster than both my parents.
Touch typing frees up your eyes. How many car wrecks might be prevented had a person not been looking at their phone to text? The device would also be much smaller than a typical keyboard. The technology could be made to fit anywhere you could fit your hand. For example, a glove, a steering wheel, a bicycle handlebar, a larger stylus for a tablet.
It may seem like a hard sell in an age of such good speech to text software, but that technolgy could be incorporated by adding a mic. And besides, it's not always polite or possible to use voice to text in social situations.
Of course it would have bluetooth connectivity, and why not a headphone jack so you wouldnt be bound to your computer by the length of your headphone jack.
The idea, like the cykey, would be a rehash of Cy Enfields original 6 button microwriter, but the joystick would replace one of the buttons. Since his had 6 buttons, I guess my original design may need changed to add an extra button on top by the joystick.
The device would be basically a cylinder with a joystick on top, The user wraps their fingers around as they would the hilt of a sword. That being the case, the user may be able to push two buttons per finger, one with the fingertip and one with the 3rd joint of the finger, without moving any fingers. The thumb could probably also operate 3 separate thumb buttons on top of the device in front of the joystick while still navigating by touch. What the function of those extra buttons would be, I dont know, either additional characters like punction, or they could be user defined. I'm glad you like the idea Glumgad!
Cykey is an interesting device, I've never heard about it before.
By the way, I've met some open source projects about it. For example https://chorder.cs.vassar.edu/doku.php?id=spiffchorder:forside
This is so close to what I imagine the device to look like: https://www.amazon.com/VR-Controller-Gamepad-Bluetooth-Control/dp/B01NAPASM1/ref=sr_1_4?ie=UTF8&qid=1512008853&sr=8-4&keywords=vr+remote+control It just needs the buttons moved around and yes, the software. I didn't know the Open Source website was a thing. I'll definitely check it out. I thought you just meant that the code should be open source. I just realized what you meant. Good tip! This could also be a good solution to the need for a keyboard for VR headsets.
About the RC controller.
I have no my own experience with this device, but I have a thing, which looks quite similar.
It is RC for smart TV. It also has TouchPad and a number of buttons.
I think it was designed to work by thumb, not fingers! As a result, it will be not convenient for your purpose.
I totally forgot about the idea of combining button presses with the 8 different joystick directions to change the function of the buttons. That would allow the device to register 479,001,600 different combinations of input presses. Should be plenty even without the extra buttons.
I had a good time thinking about your problem and how to solve it.
Not sure if you like the idea but here is what I came up with:
Use Go fund me, Kickstarter or Indiegogo to create a nice project page.
Use your ideas and ask for some nice volunteers to join the good cause of developing first prototypes.
Predictive text, multiple input options - whatever will suit the individual!
Am quite certain an idea like your will take off very quick and might even have good commercial potential.
1-10 of 22Next »
