Amatuer experiment Contest! How high can an aquarium airpump pump water? Mini airlift pump.
Here is a link about airlift pumps http://www.animatedsoftware.com/pumpglos/air_lift.htm (unfortunately the wikipedia airlift pump entry is commercial spam).
Anyway, the aquarium air pump I used produces about 2 liters of air per minute (so not so much).
So here are the contest rules.
Your airlift pump has maximum submergence of 2 ft. You must use a T-Joint to introduce the air and you use an appropriate pipe diameter to airlift the water higher. The height pumped is measured from the top of the water in the water reservoir to the top of the airlift pipe and the submergence is measured from the top of the water in the water reservoir to where air enters the T-Joint.
So, winner and Instructables world record holder is the person who pumps water highest under these conditions.
I will start with my example.
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
