3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Analog LED Bargraph?
Does anyone know if something similar to the in-13 nixie tube exists in LED form?  I'm building something where space and energy are huge constraints, and I need something, well similar to the in-13 nixie in LED form, lol.  Any ideas?
10 comments
Jan 30, 2011. 3:07 PMNachoMahma says:
. An LM3916 or similar if you don't need true analog display. You can cascade some bar-graph drivers (eg, the LM3916), to get better resolution.
Feb 11, 2011. 1:57 PMandy70707 says:
I have used a 3914 with a single LED bargraph to make a thermometer, so I would suggest this. Get a bunch of these, and LED bargraphs (or individual LEDs), and although they have digital output, you can achieve PWM. They have a threshold which can be adjusted with R1 and R2 (one controls the scale, whilst the other controls the precision, and if you stick in a mid-sized electrolytic capacitor for C1, you can have them fade. I used a 100µf capacitor and you get a very fast 1 second or so fade assuming the input doesn't change too fast. so I would suggest a 470µf or even 1000 if you want it to fade nicely. Also, remember the LEDs need to be set up with a common anode, that has caught me out a few times.
Feb 9, 2011. 10:35 PMKryptonite says:
Surface mounts?
Feb 8, 2011. 9:15 PMGoodhart says:
Have you considered a backlit LCD ?
Feb 9, 2011. 3:34 PMGoodhart says:
Ah yes, I see......quite a few things would work "except" that most of them use such high voltages.....hmmmm
Feb 7, 2011. 2:27 PMThe Skinnerz says:
led illuminating a normal thermometer could work, depending on the optical properties of the fluid, it could even act like an optical fibre. If the heat source is somewhere else, you may have to connect the bulb with a capiliary. overall, the only power is used to for illumination.
Jan 30, 2011. 12:59 PMsteveastrouk says:
Not really. An IN-13 is a truly analogue device, an LED is always discrete
Steve
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
