Another mini oodammo pistol
I had nothing better to do so I decided to build a mini pistol for the heck of it. Very little effort was put into this so don't expect much. I guess it's something simple you could build plenty of for small wars with friends indoors.
Well there's not much else to say. It gets max pin use from the tan rod pin so it should be satisfying range wise. It's durable enough to survive some small falls on carpet for sure. I just reset the trigger manually each time so that I didn't have to waste another rubber band. You can push it back while the pin is still resting but it'll catch once you pull it back. I didn't bother putting a mag pusher on but that shouldn't be hard to do. You can extend the handle if you want to.
By the way I sort of discovered a new barrel. Away with black hand barrels. If you stick a green rod in the gaps like so but also do so on the other side, it creates a barrel that fits rods quite well.
Until someone fulfills my request in my other thread, I'm at a lost for project ideas. Any requests? Something small preferably.
Picture of Another mini oodammo pistol
1-10 of 30Next »
rofl4957 years ago
I had the same Idea for a barrel and I made this one a couple months ago.
Fail.
how is this a fail.
See if you can remake the barrel, make it only a row of snowflakes linked with green rods. Its so much better.
It really doesn't make a difference.
Yes it does, it saves white rods.
And the barrel is a tonne smaller, and save a lot more pieces, and makes it easier to strengthen the handle connection.
TheDunkis (author)  ~Aeronous~7 years ago
Unless you're short for pieces, yellow rectangular barrel designs are much stronger than a single row of white connectors.
Yeah, but you wouldn't use that des.... I have an idea.
I guess I'll say my idea now just to see if I'm the first one who thought of it. It seems so simple though that I doubt it. Basically, put green rods in the gaps of either side of the yellow connectors right in the middle. Then you can put a top and bottom exactly with the top and bottom yellows. You'll have two perfectly even barrels perfect for connectors to slide through. I figured this would be useful for a compact horizontal magazine gun or a bolt action but the problem is that it's so compact that I had trouble trying to add other things.
1-10 of 30Next »
