Arc Welding Advice?
My father-in-law just gave me this 295 amp arc welding rig (he's forbidden to use it anymore--pacemaker.) It's complete with mask, rods, etc. I've never welded before, and have a couple questions:
-- Any good books or tutorials to recommend?
-- I live in an older home (1930s), which has bus fuses and certainly can't supply 295 amps without burning out (or down.)
Should I get a separate service installed for the garage? Is it expensive? I've looked on the power company website, and it's typical superficial information for the average customer...
Picture of Arc Welding Advice?
1-10 of 18Next »
weldor3 years ago
nice machine. It it a montgomery wards item? I personally wear a lot of flannel or a carhartt jacket. their ouoter shell is pretty durable but the insides are all poly something or other burst into molten goo stuff.
i added a leather throat protector to my hood to kee stuff out of my shirt and beard.
most important part of getting a good weld is a good ground connection. if i am forced to run beads on ugly metal i will put my first bead (root) down using either 6010, 6011, or 6013 rod. my fave is 6011 also referred to as farmer or dirt rod because its make up allows for a lot of forgiveness in prep.
if you are wanting to get good deep penetration bevel the edges of your work and leave a gap between the edges on a butt joint. the width of the gap is eaiest determined by using the non-fluxed end of the piece of rod you are welding with. clamp your work pieces down hard so they do not move about.
heat will cause them to walk apart so tack in the midddle and on each end to prevent thisif at all possible a 'strip' of steel at either end will allow you to start and end you arc off of the work piece. this helps to get a good stable arc going. it also helps to prevent blow out at the end of the weld. looks do count
where are you located at?
NachoMahma8 years ago
. You'll probably never need 290 amps, unless you're welding 2" steel. . You can't learn how to weld out of a book - it takes lots of practice. Try to find an experienced welder to look over your shoulder. . The welder will only pull a fraction of the 290 amps from the mains. IIRC, welding is done at about 30V (but it's been a long time since I did any welding).
. Not that reading about it won't do you any good. It's kind of like playing the piano. It helps to know some theory, but there's no substitute for getting hands-on.
gmoon (author)  NachoMahma8 years ago
Thanks for the amperage info. That fits perfectly. Until now, I really didn't know anything about the actual voltages used in these puppies. Yeah, I'm just hoping to learn some basics before the hands-on. And safety practices, too--so as not to fry either the welder or myself....
> safety practices
. Cotton fibers burns very well. Denim is great to wear when welding, but don't wear anything with frayed cuffs. Trust me, it gets hot.
. If you can afford leather (or modern equiv) gauntlets, sleeves, chaps, &c it will help.
. Make sure you use a dark enough lens. If your eyes start bothering you at all, it's not dark enough.
. When another welder hollers "Watch the arc!" they don't mean look at the arc. :)
. Don't breathe the fumes. Make sure you have plenty of ventilation and the the flow doesn't pull the smoke into your helmet.
. Do keep an eye on the wiring. It won't pull anything close to 290A, but may overtax old wiring when when you stick the rod to the metal.
  • safety practices: Cotton fibers burns very well. Denim is great to wear when welding, but don't wear anything with frayed cuffs. Trust me, it gets hot.
On the other hand, avoid (conventional) synthetic fabrics. Having your cotton shirt catch on fire is much preferred to having your polyester catch on fire, melt, and stick to you skin. Leather, Cotton, Wool. (also Kevlar and Nomex are good, but generally expensive.)
Don't wear metal jewelery, either...
Amen to that! You can just put the cotton out. Poly-whatever melting to your skin is not pleasant. I like to go to a thrift store and buy a ratty old leather jacket. They do a world of good!
gmoon (author)  skunkbait8 years ago
Great advice, Nacho, West and Skunk...
The gear does include a nice pair of leather gauntlets. And I'm aware of the synthetics issue, but it needs to be said (sometimes you just don't make those connections.)
I'm sure there's a "sunburn" effect, too (I've worked with arc-lamp platemakers, so I know about the UV component.) Which should be obvious when you put on the helmet / visor (but again, you gotta make those connections...)
. Unless you're welding in shorts, a t-shirt and goggles, "sunburn" is not a big problem. If you're like most welders, you'll have on thick pants and shirt to protect yourself from the sparks and a full hood. These will block most (if not all) of the UV.
Thanks. I'll dress appropriately.
1-10 of 18Next »
