Arduino - Python GUI
Hi all,
I'm using arduino for a while now.
For my purposes I was using matalb to communicate with it.
I want to move to python now. I started building my first python gui to control my arduino program.
The problem: I'm trying to pass a sentence which contains python's entry values to arduino, but for some reason the arduino doesn't read it.
The codes are written here.
Arduino code
#define LED 13
void setup() {
  pinMode(LED, OUTPUT);
  pinMode(2,OUTPUT);
  Serial.begin(9600);
void loop() {
  if (Serial.available()) {
    char c = Serial.read();
    if (c == 'H') {
      digitalWrite(LED, HIGH);
      digitalWrite(2,HIGH);
    else if (c == 'L') {
      digitalWrite(LED, LOW);
      digitalWrite(2,LOW);
Python code
from tkinter import *
import serial
import time
ser = serial.Serial('com7', 9600)  # com7 need to be changed for linux ^%&*^$%&$%&$%^&###@@@
time.sleep(0.2)
# ser.close()
print('serial communication started')
def pent(ard):
    s = entry1.get()
    c = bytes(s, 'utf-8')
    ard.write(c)
    time.sleep(0.5)
    # ard.write(b'H')  # the b before 'H' is conversion to bytes. needed for arduino.
    print("LED ON")
    time.sleep(0.5)
    ard.write(b'L')
    print("LED OFF")
    time.sleep(0.5)
root = Tk()
RTitle = root.title("LaserOdorPython")
root.minsize(200, 200)
root.maxsize(1400, 850)
root.geometry("300x500")
label1 = Label(root, text='Odor#\Laser', font=11)
entry1 = Entry(root)
label1.place(x=10, y=20, width=90, height=20); entry1.place(x=120, y=20, width=90, height=20)
button1 = Button(root, text='single pulse', font=8, command=lambda: pent(ser))
button1.place(x=100, y=140, width=90, height=30)
root.mainloop()
