Arduino noob, need help
Hey ive recently jumped into the wide world of arduino.
well i only did because i required the easy way out of led fading using arduino programming however i wish to use the Basics>fade example but using all 6pwm outputs!!
can anyone simply modify this for me :)
cheers
PKM7 years ago
That's the sort of request people here are likely to reply to with "No, but...". So here's my response:
> Can anyone simply modify this for me
No, but I can help if you have a specific request for explanation of something you don't understand. The basic fade example is quite a simple piece of code, so you should be able to understand what it does. The most important parts of the code are
for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=5)
and
analogWrite(ledPin, fadeValue);
If you understand what these two lines mean, you can probably write the code to fade 6 pins yourself. If you don't, I suggest you work through some of the earlier example code to get a feel for "for loops" and "analogWrite".
