Are there Phosphors that react only to specific frequencies of light?
Are there phosphors that only produce a color of visible light when struck by a specific frequency?
If so, what would happen if this phosphor was struck be two beams of light at right angles, with each beam at half the "trigger" frequency? If this would not result in an effective "trigger" frequency at that point, is there another method of achieving that effective frequency at a point, with two beams crossing at a single point, where the phosphor lies?
5
comments
Add Comment
The thought that came into my head was initially to use two low intensity lasers, focused on a block of clear acrylic with phosphors embedded throughout... however, by the result would likely be too muddled to discern, if each beam excites all the phosphors in its path, to some extent.
As I understand it, nothing. Think of it this way; you spray water at a source and then spray some from a "different" angle...will the force increase? Or will one "scatter and interfere" with the other? The latter is most likely to happen.
In the additive color model, mixing red and green produces yellow. And red and blue create magenta. But magenta is non-spectral. It's more of a mixture of two colors than a discrete wavelength.
So some of the magic of additive color is perceptual. Just like like florescent bulbs aren't full spectrum--they are a mix of narrow bands that fool the eye into perceiving white light.
Two light sources wouldn't mix at a point. They would mix proportionally to their distance. If they were carefully focused and directed to a point, there wouldn't be an advantage to use two separate sources... :-)
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
