3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Are you looking for a KNEX gun/gun-related IDEA???
I was looking at the gatling/machine guns on this site and I thought: hey! if you want to build something cool and incredibly useful, you should try and build something that helps to reload these guns, or makes more ammunition for them! it doesn't have to be automated at first, just a crank that takes a rod and/or rubber band and reloads a spent ammo belt from your favorite automtic knex weapon would be a good start!! Happy hardware hacking! -dmt
2 comments
Mar 26, 2007. 11:16 PMPerfect Duck says:
- It must stay attached to the ammo belt it is working on so that it never slips - It must properly attach to the used 'cartridge' firing pin. - It must have the strengh to pull back the firing pin's rubber band and do this quickly - It must ensure the triggers are put in position to stop the firing pins - It must, under tension, release the firing pin the same way it attached and return to be ready for the next - It must mechanically take an ammunition rod from a supply and insert it into the cartridge barrel - It must continue down the belt to repeat this process on the next - It must do all of this quickly enough to be worthwhile - It must do all of this repeatedly and without failure or the purpose of convenience is lost If all of that were mechanically simple, you'd see us doing it already. That is not to say it's impossible, however...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
