(SOLVED) Attaching Hardboard Together
Okay, so I want to make a box of hardboard. Problem is: how do I connect the pieces of hardboard together at right angles? I was planning to use a hammer and nails. I haven't worked with hardboard before. Please help!
To clarify, my question is this: How do I connect pieces of hardboard at right angles to make a box?
Thanks in advance,
~H4ZZ
https://www.instructables.com/id/Hardboard-tool-crate/
__DELETED__ (author)  Tool Using Animal6 years ago
Thank you.
Why didn't I think of that? Probably to do with my lack of wood....
Anyway, thanks.
If you don't have wood, but you do have a hot-glue gun, you can hold the pieces in place a lay a bead of hot glue along the inside of the joints.
Be aware, though, it will be nowhere near as strong as the version TUA linked to.
__DELETED__ (author)  Kiteman6 years ago
Thanks for your help, both of you.
However, I do not yet own a hot glue gun. BUT, after a good going through my dad's garage, I have found myself some perfectly sized pieces of wood.
Thanks again, both :-)
Not a problem - don't forget to take pictures of your box as you make it, and consider posting your own step-by-step instructable.
It's part of a project which has an instructable in progress. I will be including details on how to make the box.
Thanks again.
