Automatic light switch with timer and Arduino
Greetings!
I need to set up a test environment with End of Day lighting (EOD). I am a rose breeder and I read some interesting articles on the use of far-red light (740nm) followed by red light (660nm)  for a short while at EOD. The goal is to lengthen the stems of the roses by giving them EOD light in a sequence.
What I need to achieve is that by dusk (EOD) the far-red goes on for 10 minutes and then off, followed by the red light for 10 minutes and then off as well utill the next evening.
I have the following hardware:
Arduino's (Uno and Mega)
LED's (red and far-red)
Lightsensor
two relays to power the LED's transformer(s)
resistors etc.
However: I am not a programmer. Can somebody help me with the code needed for this trial? As far as I can see it should be reasonably straightforward.
Many thanks,
Peter
PetervdPol (author) 1 year ago
I have made the below sketch based on the TimeAlarm library. I want two relays to switch after each other:
meaning both off > 1 on for a given time > 1 off > 2 on for a given time > 2 off > netx cycle of almost 24 hours.
However: this does not work:
I get: Both on > 1 off > 1 on > 2 off > 2 on
Switching HIGH and LOW in the Relay code produces:
Both on > 1 off > 2 off
Now why are both on at the start and why does my sketch not work. Driving me nuts....
A time switch based on the TimeAlarm example
I want to switch realy 1 on for 5 seconds then go off after which
Relay 2 is witched on for 5 seconds and then off
However: this does not work as expected: both relays are ON immediately at 19:00
Eventually I want this to work with an RTC so I can use real time (I have a DS1307)
#include <Time.h>
#include <TimeAlarms.h>
// Pins
#define RELAY1 6
#define RELAY2 7
void setup() {
// Start Serial & set pin to output
Serial.begin(9600);
//set relays
pinMode(RELAY1, OUTPUT);
pinMode(RELAY2, OUTPUT);
// start clock
setTime(19,0,0,9,5,15); // set time to 19:00 Sep 5 2015 I want to use an RTC eventually......
// create the alarms
Alarm.alarmRepeat(19,0,5, FarRedOn); // 19:05 every day
Alarm.alarmRepeat(19,0,10,FarRedOff); // 19:00:10 every day
Alarm.alarmRepeat(19,0,11, RedOn); // 19:00:11 every day
Alarm.alarmRepeat(19,0,16, RedOff); // 19:00:16 every day
Alarm.timerRepeat(15, Repeats); // timer for every 15 seconds
Alarm.timerOnce(10, OnceOnly); // called once after 10 seconds
void loop() {
digitalClockDisplay();
Alarm.delay(1000); // wait one second between clock display
void FarRedOn(){
Serial.println("Far Red lights on");
digitalWrite(RELAY1,HIGH); // Turns ON Relay 1
delay(2000);
void FarRedOff(){
Serial.println("Far Red lights off");
digitalWrite(RELAY1,LOW); // Turns Relay 1 Off
void RedOn(){
Serial.println("Red lights on");
digitalWrite(RELAY2,HIGH); // Turns ON Relays 2
void RedOff(){
Serial.println("Red lights off");
digitalWrite(RELAY2,LOW); // Turns Relay 2 Off
void Repeats(){
Serial.println("15 second timer");
void OnceOnly(){
Serial.println("This timer only triggers once");
void digitalClockDisplay()
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.println();
void printDigits(int digits)
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
#bump#
Thanks for your thoughts , @downuner35m and @steveastrouk I am not really afraid of clouds: the level of darkness is really just before it gets really dark; but a timer could work as well for a quick trial....
So, only one shot per evening ?
As Downunder suggests, why not sense light level instead ? You'd really need a thing called a real time clock to do it by astronomical dusk timing.
What about bad weathr, big clouds?
A light sensor will react and turn your lights on.
IMHO it is easier to use a timer and to adjust the time ever two weeks or so.
