Battery pack rebuild
I read the instructable on rebuilding the 14.4v cordless tool battery pack and I've done it before with a decent Milwaukee battery. Now I have one that the thermistor is shot. It said 6k8j on it. It was a disc like an advil pill with two leads. Where would I find a replacement? I've looked on digikey.com but can't make heads or tails of it. I imagine you would want it to stop charging at 70 degrees c like a lot of r/c packs do.
Goodhart9 years ago
NachoMahma9 years ago
. I think this is what you're looking for. (Not a recommendation for this part or vendor, just the first one I found.)
. BTW, thermistors don't usually go bad. You should be reading ~6.8Kohms at room temp.
. As long as the temp/ohms curve is the same, just about any thermistor that will physically fit should work for your application.
Sunbanks9 years ago
Maybe you could try ebay?
