3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Blocking Sunlight
Would putting aluminum foil on the windows on the side of the house that gets the most sun be helpful in blocking out the heat of the sun?
Our HVAC literally runs all day, from 8am-1am, and we're trying to help cut out some of its work before it goes on strike! If you know what I mean...
Any advice?
6 comments
Jul 25, 2010. 12:56 PMGorfram says:
That's probably better - may not block quite as high a percentage of sunlight, but avoids giving your house that "Cheapskates Live Here" look that aluminum foil tends to create.
You've already changed/cleaned the filters on your HVAC system, haven't you? Right, that's good to hear. :)
Hanging outdoor shades from the eaves on that side of the house can help also, as can shades or curtains inside the house.
Be sure to open the house up at night or in the early morning when things are coolest, to let that cool air in. (If the air doesn't cool much at night, and you're really desperate, try setting an alarm for 5:00 am - get up, open doos and windows, go back to bed.) Try to set things up, assisted by fans as needed, to get good cross ventilation (http://www.sustainable-buildings.org/wiki/index.php/Cross_Ventilation).
Of course, turn off everything electrical when it's not in use. Electronics, including your computer and TV, generate a lot of heat when not  officially "on,"  so shut them down too. Don't use the oven unless you have to, and then try to pre-cook things late at night/early in the morning. (And, even though it's tempting as all get out, don't stand inside the open refrigerator door. :)
Jul 25, 2010. 1:41 PMGoodhart says:
There is that plastic sheeting that is shiny silver on one side and duller on the other: so you can reflect sunlight in the summer, and absorb it in the winter :-)
Jul 25, 2010. 1:15 PMNachoMahma says:
.  It works very well. I have some south-facing and west-facing windows that I covered the bottom 2/3 of with Al foil - makes a big difference. Works even better if the foil is placed outside the window (reflect the heat before it can enter the house).
.  The north side of my house faces the street, so it doesn't look too tacky. ;)
Jul 24, 2010. 8:59 PMTool Using Animal says:
It won't hurt, since you're willing to block the light, you'd be better getting some foil backed foam board from the hardware store and cutting plugs to fit the windows. Something I did for half my sliding glass door. BTW when was the last annual maintenance on your AC?
Jul 24, 2010. 8:40 AMcaitlinsdad says:
Using room darkening shades or curtains and having them cover the windows during the sunlight hours would help in preventing the "greenhouse" effect from heating up the room. You could tint your windows too.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
