Building a virtual campus
6
comments
Add Comment
S T A N D A L O N E A P P
PRO
Can be done in any application you want, either pre-build like 3d game engines, or self programmed in something more plattform independant.
CON
Wont run everywhere, downloading a large application since the images will most likely not load picture for picture from the web
W E B - B A S E D
-HTML, JS/CSS
PRO
Easy to build. No plugins neccesary. Very plattformindependant (if done right)
CON
Static.
-JAVA
PRO
On most plattforms available
CON
Slow. Sometimes not pre-installed
-FLASH
There are different tools, non that I know of specialized for the task though.
PRO
On most plattforms available, very common and easy to generate.
CON
Slow. No 3D. Sometimes not pre-installed. Flash Authoring is expensive if you want the "real thing" from adobe/Macromedia.
S E C O N D L I F E
..uhm... yes. Buy some land (EDUCATIONAL REBATE) and build something with images as texture.
PRO:
I can not think of anything positive except its easy and some like it. Oh yeah, it will work on mac, win and linux.
CON:
May cost a few bucks to buy land and upload.
Some stuff I found via Google and more ideas:
http://www.megalithics.com/england/belas/belachor.htm
(i also saw a 360 degrees photo-processor thing that made java tours where you could specify areas as links to switch to a different location- i searched but cant recall the name!)
VRML Standard
http://en.wikipedia.org/wiki/VRML (see linksection)
Google Earth / Sketchup
This could be a neat choice. You could build a 3d landscape on the acutal map, and i think its possible to put textures on it!
Also you could simply put links or so for higher resolution photos.
Anyway, I forgot to post this link
http://vresources.org/software/software2.shtml
which might have some usefull things.
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
