I was wondering if there's a way to use my new portable dvd player as a tv with audio video hook ups so I could plug in and xbox or ps2 or w/e. I'll get the modle in a while but its xmas and I want some custard pie MMHMHMHMHMMMMMM!!!111!1!!1!
Some portable DVD players have plugs on the side (yellow-white-red). Those will take a direct input. If it doesn't have one of those but has something else (like S-Video) then you should be able to use a converter cable...
mine has them... I tried them... I found out they were actually output... lol... can you show me a picture of a specific one that you know has input plugs?
yes you can use them for input I know this is late but you should somehow be able to set the dvd player for input either with the remote or a switch it has on the side. there is an instructable on it somewhere.
And another two years later. My portable DVD player has these RCA inputs but I can not find switch or a button on the remot that allows it to use them for input purposes. Is there any other way?
Read the manual that came with the device, if you don't have it try googleing the manufacture/model number followed by manual. Most portable dvd players cannot function as a TV, however I have seen some higher end models that can. If the plugs say RCA, or composite out, then they are not an input.
I've got two portable DVD players that have video-in capability. One is an old panasonic DVD-L75 I won in some sort of drawing, and the other is an "eSonic PD-258" I pulled from a dumpster (DVD part broken, menus in japanese, but works as a monitor.) IIRC, both of these have some sort of "setup" function that controls whether the "video" RCA jack is an output (default) or an input. I think both have s-video that is output only. I connected the eSonic to one of the spare monitor outputs on my Son's computer (via s-video to RCA converter.) The screen is JUST big enough to put up a clock :-)
Tv input taken from xbox is nothing like a technology used for flat screens, Tv uses one line (although they say so many lines, its actually only one running from top to bottom. ) tft screens use a matrix, with inputs to screen along side and top.
Void your warranty and crack one open ;) It just might have acceptable connectivity (on the insides) that you can tap into (kinda like the PSone screens) :D
If you happen to find a particular brand that has such connectivity -- do share :D
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
