Can someone give my PCB design a once over before i etch???
Hi everyone, hoping someone can help me here.
I have designed a pcb in expressPCB and was wondering if someone with a bit more knowledge and experience could give it a once over for me.  I just want to be sure there are no errors before i go away and etch this.
The design is based on a 30 channel ambilight tutorial that is here on instructables.  It uses two TLC5940 chips that are connected to an arduino.  I have left the arduino pins on the design unlabelled as they connect slightly different on each arduino (mine is a mega 1280).
Here is the design.  Please be gentle, i am just starting out with pcb design and have no breadboard at the moment. :)
Picture of Can someone give my PCB design a once over before i etch???
maddoc666 (author) 5 years ago
Well here's what i got when i designed it in Fritzing.
maddoc666 (author)  maddoc6665 years ago
And the pin-outs for the tlc5940nt.
Well you need to GENERATE the circuit diagram, because no-one in their right mind is going to pick it over for you. You haven't even identified the connector pinouts.
Steve
Jayefuu5 years ago
People are unlikely to check it for you without a circuit diagram.
maddoc666 (author)  Jayefuu5 years ago
Unfortunately, i don't have one. An instructable on here has the same idea (30 channel ambilight) but it was done using a breadboard. I was hoping i took it from the breadboard layout i seen and got it right.
Thanks for the help anyways.
