3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cant search by rating
I am unable to search instructables or anything else by rating. Was this feature removed or is it just me with this issue? If it was removed, can you quickly explain why? It would make zero sense to remove it, if someone wanted to make something or find the best of something, they can find the highest rated instructable and that will most likely be the best choice. Also, if you remove search by rating, then you should remove being able to rate stuff altogether.
Help / explain
14 comments
Aug 19, 2010. 12:31 PMThe Jamalam says:
Bump, I want that feature back.
Aug 19, 2010. 1:09 PMStumpChunkman says:
If you want to sort by rating, as lemonie suggested, change the "sort=none" or whatever else it might say at the end of a graphics search, and change it to "sort=rating"
I don't see the clickable link being put back in anytime soon (if at all). So your best bet to see something sorted by rating, is to manually enter it in.
Jul 25, 2010. 11:53 PMFred the Penguin says:
i thought you left...
Jul 30, 2010. 9:18 AMTheFoofinator says:
Same..
Jul 27, 2010. 4:11 AMajleece says:
http://www.instructables.com/tag/?q=knex&sort=rating
Jul 25, 2010. 5:48 AMqwerty987 says:
so you just type a in the search box and it will go by rating why
Jul 25, 2010. 10:38 AMlemonie says:
You add "&sort=rating" to the end of the URL.
L
Jul 25, 2010. 7:08 AMNachoMahma says:
.  Maybe
.  Or maybe, just maybe, it's the "&sort=rating" part that does the sorting and you can change "a" to the subject you are searching for..
Yes.
L
Jul 25, 2010. 9:46 AMsukinmaru says:
I can't find it either, they probably removed it. who knows why...
Jul 25, 2010. 1:00 AMMegaMetal8 says:
same here i just checked now
Jul 24, 2010. 1:43 PMstale56 says:
I don't have that option, either, so it isn't just you.
I can't think of any reason why they would get rid of that, unless they're also getting rid of the rating system (I don't know why they would do that).
You can still go by views, featured, or popular. It won't be the same as going by ratings.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
