Car, Cold, Ice, Snow and Wipers and better defrosting question
So if you live in a state that gets snow and ice one area you can never seem to get all the ice off, or the area that seems to build up ice easily is your wipers.
Now my idea is like the rear window, when you turn on the defroster it warms up wires inside of the window that melts and defrostes the snow/ice/frost etc.
A. Any ideas how I would make something like that, where I could turn on a switch that would be hooked to the battery with a fuse in the line where I could some how coil the wire around or under the wiper to melt the ice on the blade and in the area where the wipers are "stored" when turned off.
B. Any different ideas then the one above?
C. Any ways to make a roll of plastic or something with the wires held in place?
All thoughts, ideas, diagrams and explanations welcome =)
1-10 of 16Next »
Derin9 years ago
put a little cologne(about %70 ethanol) into the windshield water reservoir,and do a few cycles
Derin Derin9 years ago
or directly pour the cologne on
Sunbanks9 years ago
My dad sometimes pours hot coffee on the doors when they freeze shut.
Not a good idea to pour hot stuff on a frozen window though.
try ethanol,this is a tested method and it works wonders
Good point. He also poured coffee on a raccoon....
You know... I really have nothing to say about that... except "why?"
It was climbing over our fence.
peterhop9 years ago
Probably not a rapid de-icing, but I have had some success with a heat exchanger process by running a heated extension to the wiper washer reservoir to provide warm water to the windscreen. In application the plastic outlet tube from the wiper washer reservoir motor is intercepted and an extension is routed in several coils around the top radiator hose and back to the washers. When applied (post warm engine) the washer water is heated by the radiator hose, the more coils, the longer the warm jet of water to clean/de-ice the windshreen. Only really effective with a warming or hot engine.
PKM9 years ago
The single best way to melt ice quickly is to introduce a large amount of heat without using a high temperature, and the easiest way to do that is a large volume of warm/hot water. My dad used to leave a 5 litre bottle of water on a radiator ready to use in the morning- it would defrost an entire windscreen and not refreeze in the harshest winters the UK had to throw at us, because it didn't just melt the ice, it warmed up the windscreen as well. Other than that I'd suggest pivoting the wipers away from the screen when parking (if your wipers do that- they should, certainly) to prevent the ice from building up there. SOmetimes the best solutions are the simplest ones..
1-10 of 16Next »
