Casting pewter in RTV Silicone
By all accounts it is possible but I've run into some problems when sourcing materials.
Most high temperature silicones I have come across state a maximum temperature of 250°C, But pewter has a melting point of around 280°C.
My feeling is that the mould itself will most likely never actually reach 280°C and will probably only be above 250°C for a short period of time.
But I'm wondering if anyone has actually done this and could verify for me. Also as I'm new to the whole process, any other tips are welcomed.
This is the high temp silicone I'm currently looking at.
Thanks,
-Tom
4
comments
Add Comment
A couple years ago I did some experimenting with bismuth, which has a melting point of about 270 C. I poured the melt into silicone molds (see here). The silicone held up totally fine. I don't know exactly what temperature the molten bismuth was at, but it was obviously at least that!
Also I found that using a two part mould gave me much better results (less pitting, shiner surface, better detail) than a 1 part mould.
I've actually refined my technique quite a bit so if you want me to give you more detail on what I was doing or just show you some pictures, then let me know.
http://www.smooth-on.com/gallery.php?galleryid=424
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
