3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Chemistry set DIY gas mantle?
I'm looking for some help tracking down a chemistry experiment I tried as a child and would like to replicate.  As I recall it involved dissolving a solid (perhaps limestone) in a liquid (possibly vinegar), soaking some cloth in the resulting solution and burning it over a flame when it dried.
The idea was that the cloth would burn away and leave a mesh of whatever it was, probably lime, that acted as a mantle.  I tried it as a child and had limited success (I was too impatient to get some appropriate cloth or wait for it to dry properly) and would like to try it now that I'm older and wiser older.
If it does have to be limestone, any ideas how I can hold of small quantities without having to go to the local chalk quarry?
7 comments
Jun 19, 2011. 4:25 AMwestfw says:
Lime in small quantities is available in Mexican or Spanish Markets.
Or if you're going to disolve it in acid anywhere, there is also eggshells. Or seashells of any kind.
Mar 14, 2011. 1:36 AMcraftyv says:
I remember these gas mantles from my grandmas house so it brought back a lot of memories. Never knew anything about them. We just bought them at the hardware shop.
Mar 13, 2011. 1:36 PMQcks says:
You can pickup lime at any hardware store, and, off the top of my head, pickling lime at the grocery store.
If you're worried about the lime not being calcium oxide (as opposed to hydoxide, which i see as somewhat moot since it will hydrolize as soon you add water...) you could just roast it.
you could then mix the calcium oxide with water and soak a cloth mesh with it and allow it to dry.
That all said, I think aluminum (hydr)oxide is more what ya want. heat drives off the water and creates an oxide. aluminum hydroxide can be prepared by dissolving aluminum oxide in hydrochloric acid. After allowing a stuff to saturate a cloth mesh, heating it should drive off excess water and an aluminum oxide lattice should remain.
aluminum and it's respective hydroxides and oxides have a long list of interactions with ambient water and oxygen, and it's relatively stable.
Feb 7, 2011. 1:48 PMsteveastrouk says:
Proper mantles were made with a Thorium salt I think.
Feb 7, 2011. 3:11 PMsteveastrouk says:
Could be limelight. Whitewash would work, if you can still get it.,
Wasn't limelight struck with a hydrogen flame ?
Steve
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
