3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Circuit Design Edumacation
Can anyone direct me to free internet resources that will help me with circuit design? I can usually figure out what type of parts are needed for a given circuit, but am often completely stymied by what specific parts to select - what resistor value, which transistor, what voltage and uF cap? What's available? Thanks!
19 comments
Feb 12, 2008. 6:36 PMguyfrom7up says:
I'm pretty good with circuit design Tech-king's great with circuit design westfw is great with electronics I'm not sure how good at circuit design goodhart is... he may be great, but i dunno
Feb 13, 2008. 1:25 AMKiteman says:
Circuits? They have batteries, yes? Homba - Here's a thought, why not talk to your local high school / college? They teach the stuff, they should at least be able to point you at the right text book, even if they can't tell you themselves.
Feb 13, 2008. 4:26 AMzachninme says:
Sounds like our school >_>
Feb 13, 2008. 4:20 AMgmoon says:
The ibiblio website has some nice electronic "textbooks" in html format. Portions of the semiconductor section are incomplete, but what's there is decent...
Feb 12, 2008. 6:48 PMwestfw says:
The key epiphany is that if you're dealing with modern digital electronics, the actual values in your circuit are a lot more flexible than you might think. About the only thing you have to keep an eye on is maximum allowed current going into and out of pins and through transistors and resistors.
Feb 13, 2008. 4:20 AMzachninme says:
Phew! Thank you for finally saying that! I've been kinda pushing the values "under the rug", and I'm glad to know I'm not a bad person :P
Feb 12, 2008. 11:06 PMwestfw says:
Ah. The Joule thief circuit is far from "digital" and is pretty much in the "black magic" category as far as I'm concerned as well. Given the basic circuit is working, you should think of it as a project ripe for qualitative or quantitative experimentation; I bet one could design a pretty good science fair project around the Joule Thief circuit (eh. Not much use for us old folk...)
Feb 13, 2008. 8:07 AMwestfw says:
Highly recommended: The Art of Electronics by Horowitz and Hill. Lots of detail without making you remember your advanced calculus.
Feb 13, 2008. 12:20 PMguyfrom7up says:
that's one of my favorite electronic websites for learning. My favorite real book for electronics is practical electronics for inventors, it's pretty cheap on amazon (get the one with a blue cover with a light bulb on it)
Feb 13, 2008. 12:25 PMguyfrom7up says:
oh and for calculating the resistor for a transistor as a switch:
Take the colector current (how much current you want to go through it), and divide it by the hfe of it. Then multiply that by 1.3. then use ohms law to figure out the resistor value.
For example: I want 100mA to go through and the hfe of the transistor is 100
100/100 = 1mA
1mA x 1.3 = 1.3 mA
You need 1.3mA of base current
now caluculating the resistor, lets say we're using 5 volts:
5/0.0013= 384 ohms
Feb 13, 2008. 4:25 PMwestfw says:
Um. Probably works ok as a rule of thumb, but it's not quite "right", because for switching you want to "saturate" the transistor, which means providing significantly more base current than then Hfe would imply you need, and then the actual Hfe is usually not quite known, and somewhat variable with collector current anyway. (a lot of the complexity of fancy amplifier circuits comes from designing them in such a way where the exact values of Hfe and other transistor parameters cancel out and become irrelevant.) And then you dropped a decimal place on your last calculation. 3.84k I sorta do: "for typical currents and typical transistors, use a 1k base resistor. For low power or high power, think more." :-)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
