COMMUNITY : HELP : BUGS
Compatibility with Firefox
Have you noticed that the menu system does not appear to work with Firefox vs. 8?  When I search using this method on Firefox, I never get a link to an actual instructable.  Also, the adds seem to hover in the way of links.  However, In IE vs. 8, the links work, but some of the text and link fields overlap.  It just seems like there are some HTML programming issues that need to be addressed to make the site more navigable.
Kiteman says: Nov 29, 2011. 8:51 AM
The site is supposed to be optimised for FF, so it would be really helpful if you could include screen-shots of the problems.
As for your search issue, the box top-right gives results for the whole site, page by page and step by step.
If you want to restrict your search to the first pages of projects, start your search, then click "graphical search", then select "Instructables" from the drop-down menu.
StumpChunkman in reply to KitemanDec 2, 2011. 7:02 AM
Please don't mind me, I just want to reply to a few comments.
Kiteman in reply to StumpChunkmanDec 2, 2011. 12:09 PM
Er, OK?
(Six attempts to post this comment from two different PCs - all previous attempts evaporated)
StumpChunkman in reply to KitemanDec 2, 2011. 12:12 PM
Yeah. That should be fixed now. Someone was having fun with our filter system and added something akin to adding *.* to a file search string in dos. Apparently, that just destroys all coments...so we'll not be doing that again.
tmm2112 (author) in reply to KitemanNov 29, 2011. 9:27 AM
OK, I took two screen shots (pdfs), one of the add that overlaps text and the other is what you get when you drill down through the menus, starting with cookies. When I take the same path in IE8, it does show inks, so I knew they were there, just not showing up in FF.
Mark
Kiteman in reply to tmm2112Nov 29, 2011. 9:44 AM
Looks like both problems have the same root - the pop-up add.
Unofficially, I'd suggest installing adblocker...
lfischetti says: Nov 29, 2011. 10:30 AM
I am seeing the same behavior using FF 8. I don't mind using adblocker if I have to, but I hope you will consider fixing the issue. It doesn't reflect well on your usual commitment to quality.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
