Complicated Instructables
I was wondering whether any of you have struck the issue of trying to write an instructable that covers a particular project (in its entirety), yet quickly find that the instructable becomes rather complicated (each step requiring steps). Now splitting the instructable into bite-sized instructables would work, but then is it best to have a main instructable that points to each mini-instructable at each step, or simply have links from one instructable to the other, or explain at the beginning of each instructable that it is a part of a group of instructables (overall project) with links to each mini-instructable.
As an example, How to Host a Spy Party is a little convoluted, as some of the initial steps Making Invitations or Making a Pinata could probably be instructables in their own right (yet I didn't want to split the project up for continuity's sake. How would you have tackled my Spy Party instructable (splitting it up... not even attempting it... or...???).
I guess an example of the opposite case (really, did it need a whole instructable to express a simple tip) could be How to Fix a Broken Superhero (without glue), where really I wanted to share the idea of using a screw, bolt or pin to fix something plastic (as I found glue kept breaking and restricted the action figure's movement and I hadn't thought of this method)... Do you think there would be a place for mini-ibles or tip-ibles (that could be used across the instructables categories)?
I would love to hear your thoughts (especially on how to keep an instructable straight forward when theres lots to cover. I'm about to write an instructable on Mushroom Cultivation and don't know if I should write one instructable with lots of detail or two separate instructables (one on the basic growing of mushrooms and one covering how to reproduce mushroom spawn'- how should these be linked???)...
Many thanks for your ideas... uniqueutopia
comments
Add Comment
As you write an instructable, it can grow unexpectedly and you do have to edit yourself on the number of steps. I guess the best thing is to read it over several times from the point of view of the average reader to make sure it flows and is understandable. It is okay to link back to other instructables if they contain more detail on making something and would distract or take off topic from the overall intent of the current instructable. Of course, having a previous instructable is nice so that you don't have to repeat yourself and make the instructable longer than necessary.
Writing an instructable should not turn out to be a chore. Just go with the flow and have fun with it.
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
