Connect Leds to sound activated driver
Hi,
I want to connect an array of white leds to this sound reactive driver:
http://worldaglow.com/rcProd1.asp?id=556&c1=4&c2=149
I'm pretty sure the output is 100 volt at 2000Khz. What is the cheapest way to do this ?
guyfrom7up8 years ago
just put 30 white leds in series and put a 500 ohm resistor in series with that. I'm not 100% if that'll work with the given setup, as I need more specs, like current and what it's for and I'm not sure you can run LEDs off of an EL driver
fade400 (author)  guyfrom7up8 years ago
First off .. thanks for your input. Second, the reason i posted is cuz LEDs run off DC.
