Connecting small generators in series?
I'd like to make a bunch of small generators, like Pleech turbines, for example. Each one might only be producing a couple volts and however much power. What is the best way to connect them together to get their combined power?
I was thinking that I could just give each generator its own rectifier, and then connect everything together in series. Would that be efficient?
My circuitry understanding is a little limited, so a simple solution that is 90% efficient may be better than a complicated solution that's 100% efficient.... :)
Thanks for any suggestions!
9
comments
Add Comment
It looks to me like it would be ok after all -- the current prefers to go through the low-resistance diodes in the rectifying bridge rather than going through the load. So it seems that having a stopped generator in series with everything else is not much worse than having no generator at all.
Does that seem right to you (or anyone)? My circuit is probably simplistic, but is it roughly accurate? Am I making a mistake somewhere?
Thanks!
Vancouver Mini Maker Faire 2012
Rebuilding NordicTrack ski machine drive rollers
Looking for New Zealand-based Instructables authors for conference on August 27 in Wellington
Call to makers - Brighton Mini Maker Faire
Milk Crates - not as green as you think
TEDxBaghdad - Iraq - violence, dust storms and open sourced manufacturing
UK Mini Maker Faire - The Derby Silk Mill - New Poster to Share!
