Controlling a DC motor to only do one rotation and to be triggered using limit switch.
Hi,
I'm designing a mini golf hole for a festival in 3 weeks. The idea is to putt the ball in one hole and another ball to be released on another hole. I'm going to use a limit switch to as the trigger signal, but not sure how to get only one rotation on a dc motor and then to reset the trigger.
I have to run the whole circuit off 12v battery's.
Any and all help would be greatly appreciated.
Thanks!
Thanks!
Lomography Konstructor - World's First 35mm DIY SLR
Office Warfare Book on Sale Now
List of Upcoming Contests (updated 6/6)
Spanish translations of Instructables / Instructables traducidos al Espanol
JULY 2013 Build Night with SUGRU
High-current, electronic sword-fighting, fancy drink pouring, and more @ Makers Local 256 Build Night!
New Instructables Books for 2013
Souped Up: Projects to Make Everything Better [Book]
Backyard Rockets Book on Sale Now
Visit Our Store »
Go Pro Today »
What is the motor doing? Lifting a ball out? Opening a gate?
What will happen to the first ball that goes down the hole? Will it carry on into a hopper or stay on the limit switch?
The first ball will drop on a plate which will trigger the limit switch then fall into a hopper.
Thanks Jayefuu
You need a DPDT relay. A/2 is the relay coil. A1 is one of the relay contacts and A2 is the other one.
When the ball drops down the first hole LIM1 will close, turning on the relay. This in turn closes A2. The relay will stay energised even when the ball has gone from LIM1.
Since the relay turned on, A1 will have closed and so the motor will be turning.
The motor will remain on until the relay is turned off by a contact on the ball release gate pushes on limit switch two, opening limit switch 2 and turning off the relay.
Any questions?
