Copper chloride without H2O2-adding?
Hi!
I think i will see some PCB-Etchin in the future... So i will need an etchant. Aequous copper chloride was the choice i made since it is a regenerative etchant according to several sources.
Now if i understood the chemistry right (Sorry... electrotechnician here), the reaction in theory only needs the oxygen from the peroxide (H2O2) and the hydrogen isnt used at all?
Since i only have relatively weak peroxide, i plan on using a bubbler to introduce the oxygen to the copper-HCI-mix. This because i dont want to dilute the acid too much...
Will that work?
I know that if i use normal air (which has only around 20% oxygen in it) it will take some time... But would it work in the first place?
I read somewhere that copper and muriatic acid dont really react in the first place...
So if i also understood that right, it needs the oxygen present in the beginning to START reacting... So i think i may go with a contraption like:
Will that work?
- Plastic container with a bubbler installed (Pumps normal air)
- Add Muriatic acid to the container
- Add copper to the acid
- let it bubble till the copper is disolved
Now i have a copper chloride-solution which i can regenerate by adding oxygen (By bubbler or H2O2)?
New Instructables Books for 2013
Souped Up: Projects to Make Everything Better [Book]
Backyard Rockets Book on Sale Now
Awesome Discounts for Pro Members
JUNE 2013 Build Night - 3D Printing with 123D & Tinkercad
Instructables Build Night w/ Bare Conductive @ Noisebridge
Embed a 3D viewer in your Instructable
Maker Faire 2013 Slide Show!
Fried Contest Launches 5/13, HQ Celebrates with Fried Day Friday
MEH! :D A Build Night at Montana Ethical Hackerspace!
Visit Our Store »
Go Pro Today »
And 3% is what i found in Switzerland...
Also what made me think is the PRINCIPLE of creating CuCl2 without added H2O2 int he first place. Call it a chemical experiment... :)
If i understood it right, the solution uses chloride + oxygen to disolve copper and oxidizing it from Cupric chloride to Copper (or Cuprous?) chloride.
So in my simple minded theory it SHOULD be possible to start with Cu + HCl and a bubbler to supply the oxygen from the air...
THATS the question here... :)
Sorry if i didnt wrote that clear enough... English isnt my language... ;)
